Updated to latest version today and services failed to start… debug logs below… not sure if any of the “segmentation fault” errors are a problem… or what they mean.
Any pointers would be welcomed ?
0.4.9
Flashed OS version
v0.3.10
Raspberry Pi Model
Revision : c03114
Serial : 100000001ac37bd5
Firmware
Feb 25 2021 12:10:40
Copyright © 2012 Broadcom
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start)
Temperature
temp=56.0’C
Throttling
throttled=0x0
Mem: 3.8G 379M 2.7G 8.0M 665M 3.3G
Swap: 4.1G 0B 4.1G
total: 10.0%
system: 10%
tor: 0%
thunderhub: 0%
sphinx-relay: 0%
specter-desktop: 0%
mempool: 0%
lnd: 0%
electrs: 0%
btcpay-server: 0%
bluewallet: 0%
bitcoin: 0%
Memory monitor logs
2022-05-18 19:42:25 Memory monitor running!
2022-05-18 19:42:36 Memory monitor running!
2022-05-18 19:42:47 Memory monitor running!
2022-05-18 19:42:58 Memory monitor running!
2022-05-18 19:43:09 Memory monitor running!
2022-05-18 19:43:21 Memory monitor running!
2022-05-18 19:43:32 Memory monitor running!
2022-05-18 19:43:43 Memory monitor running!
2022-05-18 19:43:54 Memory monitor running!
2022-05-18 19:44:05 Memory monitor running!
/dev/root 118G 3.1G 110G 3% /
/dev/sda1 916G 523G 347G 61% /home/umbrel/umbrel
Startup service logs
May 18 19:43:53 umbrel umbrel startup[19808]: Starting status monitors…
May 18 19:43:53 umbrel umbrel startup[19808]: Starting memory monitor…
May 18 19:43:53 umbrel umbrel startup[19808]: Starting backup monitor…
May 18 19:43:53 umbrel umbrel startup[19808]: Starting decoy backup trigger…
May 18 19:43:53 umbrel umbrel startup[19808]: Starting Docker services…
May 18 19:43:54 umbrel umbrel startup[19808]: /home/umbrel/umbrel/scripts/start: line 115: 19831 Segmentation fault docker-compose up --detach --build --remove-orphans
May 18 19:43:54 umbrel umbrel startup[19808]: Failed to start containers
May 18 19:43:54 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
May 18 19:43:54 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
May 18 19:43:54 umbrel systemd[1]: Failed to start Umbrel Startup Service.
May 18 19:44:04 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
May 18 19:44:04 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 42.
May 18 19:44:04 umbrel systemd[1]: Stopped Umbrel Startup Service.
May 18 19:44:04 umbrel systemd[1]: Starting Umbrel Startup Service…
May 18 19:44:04 umbrel umbrel startup[20108]: ======================================
May 18 19:44:04 umbrel umbrel startup[20108]: ============= STARTING ===============
May 18 19:44:04 umbrel umbrel startup[20108]: ============== UMBREL ================
May 18 19:44:04 umbrel umbrel startup[20108]: Setting environment variables…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting karen…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting status monitors…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting memory monitor…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting backup monitor…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting decoy backup trigger…
May 18 19:44:04 umbrel umbrel startup[20108]: Starting Docker services…
May 18 19:44:05 umbrel umbrel startup[20108]: /home/umbrel/umbrel/scripts/start: line 115: 20131 Segmentation fault docker-compose up --detach --build --remove-orphans
May 18 19:44:05 umbrel umbrel startup[20108]: Failed to start containers
May 18 19:44:05 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
May 18 19:44:05 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
May 18 19:44:05 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Wed 2022-05-18 19:35:43 UTC, end at Wed 2022-05-18 19:44:05 UTC. –
May 18 19:35:48 umbrel systemd[1]: Starting External Storage Mounter…
May 18 19:35:48 umbrel external storage mounter[507]: Running external storage mount script…
May 18 19:35:48 umbrel external storage mounter[507]: Found device “External USB3.0”
May 18 19:35:48 umbrel external storage mounter[507]: Blacklisting USB device IDs against UAS driver…
May 18 19:35:48 umbrel external storage mounter[507]: Rebinding USB drivers…
May 18 19:35:48 umbrel external storage mounter[507]: Checking USB devices are back…
May 18 19:35:48 umbrel external storage mounter[507]: Waiting for USB devices…
May 18 19:35:49 umbrel external storage mounter[507]: Waiting for USB devices…
May 18 19:35:50 umbrel external storage mounter[507]: Checking if the device is ext4…
May 18 19:35:50 umbrel external storage mounter[507]: Yes, it is ext4
May 18 19:35:51 umbrel external storage mounter[507]: Checking if device contains an Umbrel install…
May 18 19:35:51 umbrel external storage mounter[507]: Yes, it contains an Umbrel install
May 18 19:35:51 umbrel external storage mounter[507]: Bind mounting external storage over local Umbrel installation…
May 18 19:35:51 umbrel external storage mounter[507]: Bind mounting external storage over local Docker data dir…
May 18 19:35:51 umbrel external storage mounter[507]: Bind mounting external storage to /swap
May 18 19:35:51 umbrel external storage mounter[507]: Bind mounting SD card root at /sd-card…
May 18 19:35:51 umbrel external storage mounter[507]: Checking Umbrel root is now on external storage…
May 18 19:35:52 umbrel external storage mounter[507]: Checking /var/lib/docker is now on external storage…
May 18 19:35:52 umbrel external storage mounter[507]: Checking /swap is now on external storage…
May 18 19:35:52 umbrel external storage mounter[507]: Setting up swapfile
May 18 19:35:52 umbrel external storage mounter[507]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
May 18 19:35:52 umbrel external storage mounter[507]: no label, UUID=513fbc7a-da4f-4389-82f2-21a75b3df04a
May 18 19:35:52 umbrel external storage mounter[507]: Checking SD Card root is bind mounted at /sd-root…
May 18 19:35:52 umbrel external storage mounter[507]: Starting external drive mount monitor…
May 18 19:35:52 umbrel external storage mounter[507]: Mount script completed successfully!
May 18 19:35:52 umbrel systemd[1]: Started External Storage Mounter.
May 18 19:36:04 umbrel systemd[1]: Starting External Storage SDcard Updater…
May 18 19:36:04 umbrel external storage updater[1715]: Checking if SD card Umbrel is newer than external storage…
May 18 19:36:05 umbrel external storage updater[1715]: No, SD version is not newer, exiting.
May 18 19:36:05 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal:
karen is getting triggered!
Got signal:
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
Docker containers
NAMES STATUS
manager Up 8 minutes
bluewallet_lndhub_1 Restarting (3) 57 seconds ago
btcpay-server_web_1 Up 8 minutes
mempool_api_1 Up 8 minutes
sphinx-relay Up 8 minutes
lnd Restarting (1) 51 seconds ago
Umbrel logs
/home/umbrel/umbrel/scripts/debug: line 131: 20801 Segmentation fault docker-compose logs --tail=30 manager middleware
Bitcoin Core logs
/home/umbrel/umbrel/scripts/debug: line 137: 20805 Segmentation fault docker-compose logs --tail=30 bitcoin
LND logs
/home/umbrel/umbrel/scripts/debug: line 143: 20813 Segmentation fault docker-compose logs --tail=30 lnd
electrs logs
/home/umbrel/umbrel/scripts/debug: line 149: 20833 Segmentation fault docker-compose logs --tail=30 electrs
Tor logs
/home/umbrel/umbrel/scripts/debug: line 155: 21098 Segmentation fault docker-compose logs --tail=10 tor app_tor app_2_tor app_3_tor
App logs
bluewallet
./scripts/app: line 103: 21225 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
btcpay-server
./scripts/app: line 103: 21283 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
mempool
./scripts/app: line 103: 21356 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
specter-desktop
./scripts/app: line 103: 21410 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
sphinx-relay
./scripts/app: line 103: 21462 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
thunderhub
./scripts/app: line 103: 21550 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --file “${app_compose_file}” “${@}”
==== Result ====
