Error in regards to the Bitcon Node
Hi community!
I have the problem, that sometimes my Bitcoin node just stops synchronizing, so with other words the SSD is not in use anymore (no flashing light anymore from the wavlink). Then i close the Bitcoin app and try to do a troubleshooting again, but it can not generating the logs… it’s just freezing.
Then i need to reboot and even that is not working sometimes. No restart and no shutdown is working… Also no ssh…
So i did a troubleshooting and this is the error message in the report (this report comes while it is working):
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1
i2pd_daemon_1 | 23:02:41@579/error - Tunnels: Can’t select next hop for tSC5WDnkwyLCVgjrYyHQ1m8ibSn9~FfIRRRDhsm442c=
i2pd_daemon_1 | 23:02:41@579/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 23:02:56@579/error - Tunnels: Can’t select next hop for d6gnw0zGlAlstFKwCDTOMAWiaT80-MCu3~lgbjIeIB4=
i2pd_daemon_1 | 23:02:56@579/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 23:03:02@767/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 23:03:13@767/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 23:03:16@767/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 23:03:18@767/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 23:03:26@579/error - Tunnels: Can’t select next hop for KXeh5ZWu~mNJsYoVeo5N5QCWCyVY5Ba6nRUrZiqm9JE=
i2pd_daemon_1 | 23:03:26@579/error - Tunnels: Can’t create inbound tunnel, no peers available
bitcoind_1 | 2024-03-30T23:04:08Z UpdateTip: new best=0000000000000000000355c29c6f245daf67b7e6cfbddd0181d892ef9bb90992 height=836289 version=0x20110000 log2_work=94.818746 tx=980444568 date=‘2024-03-25T22:22:37Z’ progress=0.997559 cache=14.1MiB(122916txo)
May anyone knowledgeable let me know, if that says something about the reason in regards to my problem?
Thank you in advance!!
Yeah im having trouble starting bitcoin core too since the last update. Restart app or umbrel has no effect. Here are my logs: Garuda's PrivateBin
…and its working again…its a bit wonky
