Bitcoin dont start sync
Hello class! My node stopped, bitcoin core does not start synchronizing. I opened the bitcoin log and found this error: Does anyone have a solution??
i2pd_daemon_1 | 05:58:04@64/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 05:58:16@549/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
i2pd_daemon_1 | 05:58:21@64/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 06:02:37@67/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
i2pd_daemon_1 | 06:02:38@67/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
i2pd_daemon_1 | 06:05:06@549/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
i2pd_daemon_1 | 06:07:30@378/error - Tunnels: Can’t select next hop for …-…-…-…-…-…-…-…
i2pd_daemon_1 | 06:07:30@378/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 06:08:17@549/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
i2pd_daemon_1 | 06:15:36@67/error - Garlic: Can’t handle …-…-AEAD-Ratchet message
Hi, i have the same problem, did you found a solution?
not yet
i make script stop/ star bitcoin and resolve
