What are these errors and how can I fix it?
As far as I researched they may be related to NTP as discussed on the following post:
https://bbs.archlinux.org/viewtopic.php?id=110718
But I don’t understand how exactly to resolve it in Umbrel.
The command I run is:
sudo journalctl -p 4 -x -b
And this is the ntpsec service. Not sure what I should change.
The ntp.conf file:
Here’s how I fixed it:
sudo nano /usr/libexec/ntpsec/ntp-systemd-wrapper
Then modify the line in the middle to be:
NTPD_OPTS="$NTPD_OPTS -4 -u ntpsec:ntpsec"
The -4 forces the service to use only IPv4
Then to reload the change and then restart the service:
systemctl daemon-reload
systemctl restart ntpsec
After 30 minutes, check logs to verify the errors are gone:
sudo journalctl -p 4 | less +G
You can also verify that the service now includes -4 in the options with this command:
systemctl status ntpsec.service
If anyone from Umbrel sees this, this change to the file should be built-in into Umbrel when installed fresh, because it’s a bug.
