ElectrumX - taking very long to synch
I have downloaded the ElectrumX to use with my Sparrow Wallet. So far, after 24 hours, it is still synching. Right now, it is 50% synched. How long does it usually take?
If you tell me what hardware you are using, I can tell you if it is normal. :wink:
Raspberry pi4
Then it can actually take that long. The synchronization should be completed after 24-48 hours.
It’s been three days now. I’m at 59% now. Just out of curiosity, in order for my wallet to plug into umbrel, do I need to use the Election server? Is that the only way?
You should be patient. It is the only way to connect your wallet to Umbrel.
Any Electrum server takes a long to sync in slower computers. ElectrumX, as far as I know, can take ~2 weeks to sync in a RPi.
Yes, I noticed that. It also slows down the RPi such that it slows down the routing of payments and balancing of channels.
Rpi 5 with 8GB RAM
INFO:DB:sync time: 16h 48m 25s ETA: 12d 08h 50m
