For some reason Electrs still waiting node to sync, but it 100% sync already
Can you please try running this and sharing them with this https://pastebin.com/
sudo ~/umbrel/scripts/app compose electrs logs --tail=600
I have the same problem. My Umbrel is running since 3 weeks, the bitcoin node is synced and works flwaless since 2 weeks.
Tryed to reeinstall electr doesnt solve the problem.
Electr log → Logfile
Can anyone help me with this issue?
Thx and bb
Ok i found the problem with github - reverted the changes in my bitcoin.conf
maxconnections and maxuploadtarget back to default
Now electrs started syncing again
Can you please refer me to the link with the solution?
thanks
