Electrs sync stalled
Non-technical (at least as far as computers are concerned) node noob here. Also, first ever post on a BTC forum!
My BTC node has completed the sync, but Electrs (v 0.9.10) will not sync. The progress will not go past 22 or 23%. I’ve remove/reinstalled it, waited a few days after node sync… Sometimes it just says that it’s waiting for the node to sync, which it has already done.
Reading through other posts, I can’t even generate a log of what the problem for more specific guidance so that may be my first request for help.
Hi @Syturio , are you still using Umbrel or did you switch to something else? I feel the vibes are still the same unfortunately and even asking for help is not resolving my issues
I finallt found a solution: Start9 Embassy. Never a crash, never a doubt about what to do, simply working. Thanks for the support, bye!
