Duplicati "Login failed: Unauthorized"
Installed Duplicati, prompted for login, entered umbrel password (and every other possible password I can think of), reply is “Login failed: Unauthorized.” Uninstalled Duplicati, re-installed, same outcome. How can I either get in to Duplicati or scrub it entirely from my umbrel home and start over? Thanks in advance.
I had the same experience, new Umbrel, downloaded Duplicati from the App Store, asks for password says “Login failed: Unauthorized”
I figured it out! If you right click on Duplicati on the Umbrel home page, there is an option “Show default credentials”. You can copy them from here and login.
when opening the app there is a prompt with the login password, you can copy this also without showing.
Was this the solution?
