Dennys Umbrel App Store ☂️
Thanks for RustDesk.
Is ZNC (irc) possible?
Hey!
RustDesk doesn’t support ZNC/IRC directly. You can run ZNC in a separate Docker container and configure the network accordingly. A direct integration isn’t possible.
Added Nexterm.
Added Mullvad Browser.
This would be to compete with Start9 as they have the app in their store. Also, Sparrow Desktop Wallet is a strong choice for experienced Bitcoin users, offering advanced privacy features like Tor and CoinJoin, multi-signature support, and cold storage integration with hardware wallets. It’s open-source and provides fine control over transactions and is best suited for users prioritizing security and privacy in their Bitcoin management.
I wonder if we can use the same docker package that Start9 uses.
I know Sparrow Wallet.
The question is rather whether it makes sense to install a wallet on the same device on which the node is operated. You could also simply connect the wallet to Umbrel from any device that is running Sparrow Wallet.
So the question is, what added value does it offer?
Problems to start Joplin on my rasp 5 with umbrel. The logfile: denny-joplin_app_1 | exec /usr/local/bin/tini: exec format error
what can I do???
Hey! :smiley:
Joplin Server currently only runs on AMD64 architecture devices (e.g., standard PCs, servers) or on Umbrel Home, which uses compatible hardware. Unfortunately, it won’t work on a Raspberry Pi unless an ARM-compatible image is made available.
I’d like to try it. If you’re interested, you’re welcome to help me with this.
Added Lucky.
Added VoceChat. (App No. 100 :partying_face:)
Added Changedetection.
Hi, is it possible to add Mumble to your Store?
mumble.info
Thanks for your suggestion! :blush:
As far as I know, the official Mumble Docker image doesn’t include a web interface. If there’s a version with a web UI, I’d be happy to take a look and consider adding it to my app store. Feel free to correct me if I’m wrong!
Hi, i think there is a web enhanced version:
GitHub - olaulau/mumble-server-web-enhanced: mumble web interface, based on the mumble-server-web old package
This version is over 11 years old. :flushed:
Added Gitingest. (Tip)
Hi, is it possible to add mullvad. Im not sure if there is a container with a gui
Dennys Umbrel App Store ☂️ - #124 by denny :sunglasses:
