Would you consider adding Riven and Zurg?
Hey @fuzzynet!
Thanks for your suggestions. I’ll add the apps to my list. ![]()
Added Cloudreve.
BookStack is broken. Here is my log
"denny-bookstack_app_1 | [migrations] started
denny-bookstack_app_1 | [migrations] 01-nginx-site-confs-default: executing…
denny-bookstack_app_1 | [migrations] 01-nginx-site-confs-default: succeeded
denny-bookstack_app_1 | [migrations] 02-default-location: executing…
denny-bookstack_app_1 | [migrations] 02-default-location: succeeded
denny-bookstack_app_1 | [migrations] done
denny-bookstack_app_1 | ───────────────────────────────────────
denny-bookstack_app_1 | ██╗ ███████╗██╗ ██████╗
denny-bookstack_app_1 | ██║ ██╔════╝██║██╔═══██╗
denny-bookstack_app_1 | ██║ ███████╗██║██║ ██║
denny-bookstack_app_1 | ██║ ╚════██║██║██║ ██║
denny-bookstack_app_1 | ███████╗███████║██║╚██████╔╝
denny-bookstack_app_1 | ╚══════╝╚══════╝╚═╝ ╚═════╝
denny-bookstack_app_1 | Brought to you by linuxserver.io
denny-bookstack_app_1 | To support LSIO projects visit:
denny-bookstack_app_1 | Donate | LinuxServer.io
denny-bookstack_app_1 | GID/UID
denny-bookstack_app_1 | User UID: 1000
denny-bookstack_app_1 | User GID: 1000
denny-bookstack_app_1 | Linuxserver.io version: v24.12.1-ls190
denny-bookstack_app_1 | Build-date: 2025-01-22T00:21:32+00:00
denny-bookstack_app_1 | Setting resolver to 127.0.0.11
denny-bookstack_app_1 | Setting worker_processes to 4
denny-bookstack_app_1 | generating self-signed keys in /config/keys, you can replace these with your own keys if required
denny-bookstack_app_1 | …+…+.+..+…+..+…+…+…+…+…+++++++++++++++++++++++++++++++++++++++…+..+…+..+…+…+++++++++++++++++++++++++++++++++++++++.+..+…+…+..+…+…+…+…+.+..+.+…+..+…+.+…+…+…+…+..+…+…+.+…+…+…+.+…+…+…+…+…+…+…+…+…+.+…+.+…+..+…+…+…+.+…+…+…+..+.+..+…+…+..+…+…+…+…+…+…+…+…+…+…+…+..+…+…+…+…+…+…+.+..+.+…+…+..+…+…+…+…+.+..+…+…+…+…+.+…++++++
denny-bookstack_app_1 | …+…+…+++++++++++++++++++++++++++++++++++++++…+..+…+…+…+…+..+…+.+…+…+…+…+…+…+…+…+…+..+.+..+++++++++++++++++++++++++++++++++++++++…+.+…+..+.+..+…+.+…+…+.+…+…+..+…++++++
denny-bookstack_app_1 | -----
denny-bookstack_app_1 | Waiting for DB to be available
denny-bookstack_app_1 | Illuminate\Database\QueryException
denny-bookstack_app_1 | SQLSTATE[HY000] [1045] Access denied for user ‘bookstack’@‘10.21.0.37’ (using password: YES) (Connection: mysql, SQL: select table_name as name, (data_length + index_length) as size, table_comment as comment, engine as engine, table_collation as collation from information_schema.tables where table_schema = ‘bookstackapp’ and table_type in (‘BASE TABLE’, ‘SYSTEM VERSIONED’) order by table_name)
denny-bookstack_app_1 | at /app/www/vendor/laravel/framework/src/Illuminate/Database/Connection.php:829
denny-bookstack_app_1 | 825▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
denny-bookstack_app_1 | 826▕ );
denny-bookstack_app_1 | 827▕ }
denny-bookstack_app_1 | 828▕
denny-bookstack_app_1 | ➜ 829▕ throw new QueryException(
denny-bookstack_app_1 | 830▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
denny-bookstack_app_1 | 831▕ );
denny-bookstack_app_1 | 832▕ }
denny-bookstack_app_1 | 833▕ }
denny-bookstack_app_1 | +36 vendor frames
denny-bookstack_app_1 | 37 /app/www/artisan:35
denny-bookstack_app_1 | Illuminate\Foundation\Console\Kernel::handle()
denny-bookstack_app_1 | [custom-init] No custom files found, skipping…
denny-bookstack_app_1 | [ls.io-init] done.
denny-bookstack_app_proxy_1 | yarn run v1.22.19
denny-bookstack_app_proxy_1 | $ node ./bin/www
denny-bookstack_app_proxy_1 | [HPM] Proxy created: / → http://denny-bookstack_app_1:80
denny-bookstack_app_proxy_1 | Waiting for denny-bookstack_app_1:80 to open…
denny-bookstack_app_proxy_1 | BookStack is now ready…
denny-bookstack_app_proxy_1 | Listening on port: 8875
denny-bookstack_db_1 | [migrations] started
denny-bookstack_db_1 | [migrations] no migrations found
denny-bookstack_db_1 | ───────────────────────────────────────
denny-bookstack_db_1 | ██╗ ███████╗██╗ ██████╗
denny-bookstack_db_1 | ██║ ██╔════╝██║██╔═══██╗
denny-bookstack_db_1 | ██║ ███████╗██║██║ ██║
denny-bookstack_db_1 | ██║ ╚════██║██║██║ ██║
denny-bookstack_db_1 | ███████╗███████║██║╚██████╔╝
denny-bookstack_db_1 | ╚══════╝╚══════╝╚═╝ ╚═════╝
denny-bookstack_db_1 | Brought to you by linuxserver.io
denny-bookstack_db_1 | To support LSIO projects visit:
denny-bookstack_db_1 | Donate | LinuxServer.io
denny-bookstack_db_1 | GID/UID
denny-bookstack_db_1 | User UID: 1000
denny-bookstack_db_1 | User GID: 1000
denny-bookstack_db_1 | Linuxserver.io version: 11.4.4-r1-ls171
denny-bookstack_db_1 | Build-date: 2025-01-22T17:54:07+00:00
denny-bookstack_db_1 | Setting Up Initial Databases
denny-bookstack_db_1 | Installing MariaDB/MySQL system tables in ‘/config/databases’ …
denny-bookstack_db_1 | OK
denny-bookstack_db_1 | To start mariadbd at boot time you have to copy
denny-bookstack_db_1 | support-files/mariadb.service to the right place for your system
denny-bookstack_db_1 | PLEASE REMEMBER TO SET A PASSWORD FOR THE MariaDB root USER !
denny-bookstack_db_1 | To do so, start the server, then issue the following command:
denny-bookstack_db_1 | ‘/usr/bin/mariadb-secure-installation’
denny-bookstack_db_1 | which will also give you the option of removing the test
denny-bookstack_db_1 | databases and anonymous user created by default. This is
denny-bookstack_db_1 | strongly recommended for production servers.
denny-bookstack_db_1 | See the MariaDB Knowledgebase at MariaDB Knowledge Base
denny-bookstack_db_1 | You can start the MariaDB daemon with:
denny-bookstack_db_1 | cd ‘/usr’ ; /usr/bin/mariadbd-safe --datadir=‘/config/databases’
denny-bookstack_db_1 | You can test the MariaDB daemon with mariadb-test-run.pl
denny-bookstack_db_1 | cd ‘/usr/mariadb-test’ ; perl mariadb-test-run.pl
denny-bookstack_db_1 | Please report any problems at https://mariadb.org/jira
denny-bookstack_db_1 | The latest information about MariaDB is available at https://mariadb.org/.
denny-bookstack_db_1 | Consider joining MariaDB’s strong and vibrant community:
denny-bookstack_db_1 | Contribute - MariaDB.org
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] Starting MariaDB 11.4.4-MariaDB source revision e9a502df08bad16aa8a354e854f3c014b1380e32 server_uid m9sfq/9doBUMtvudVVNg5kruT+A= as process 169
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Compressed tables use zlib 1.3.1
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Number of transaction pools: 1
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] mariadbd: O_TMPFILE is not supported on /var/tmp (disabling future attempts)
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Using Linux native AIO
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Completed initialization of buffer pool
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: End of log at LSN=47629
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Opened 3 undo tablespaces
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: 128 rollback segments in 3 undo tablespaces are active.
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: log sequence number 47629; transaction id 14
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] Plugin ‘FEEDBACK’ is disabled.
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] Plugin ‘wsrep-provider’ is disabled.
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Loading buffer pool(s) from /config/databases/ib_buffer_pool
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] InnoDB: Buffer pool(s) load completed at 250521 2:28:11
denny-bookstack_db_1 | 2025-05-21 2:28:11 0 [Note] mariadbd: Event Scheduler: Loaded 0 events
denny-bookstack_db_1 | 2025-05-21 2:28:12 0 [Note] mariadbd: ready for connections.
denny-bookstack_db_1 | Version: ‘11.4.4-MariaDB’ socket: ‘/run/mysqld/mysqld.sock’ port: 0 Alpine Linux
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] mariadbd (initiated by: root[root] @ localhost ): Normal shutdown
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: FTS optimize thread exiting.
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: Starting shutdown…
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: Dumping buffer pool(s) to /config/databases/ib_buffer_pool
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: Buffer pool(s) dump completed at 250521 2:28:13
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] InnoDB: Shutdown completed; log sequence number 47629; transaction id 16
denny-bookstack_db_1 | 2025-05-21 2:28:13 0 [Note] mariadbd: Shutdown complete
denny-bookstack_db_1 | Database Setup Completed
denny-bookstack_db_1 | [custom-init] No custom files found, skipping…
denny-bookstack_db_1 | 250521 02:28:14 mysqld_safe Logging to ‘/config/log/mysql/mariadb-error.log’.
denny-bookstack_db_1 | 250521 02:28:14 mysqld_safe Starting mariadbd daemon with databases from /config/databases
denny-bookstack_db_1 | Connection to localhost (127.0.0.1) 3306 port [tcp/mysql] succeeded!
denny-bookstack_db_1 | Logrotate is enabled
denny-bookstack_db_1 | [ls.io-init] done.
I made a change to the database. It should work again now.
Added Airstation.
Added Supabase.
No problem at all. I managed to install it through the terminal. I was just happy earning some passive income that’s all.
Added Docmost.
Added EmulatorJS.
Amusewiki is “a library-oriented wiki engine.” Enter the text once, it exports into just about every format you could hope for plus it has a book-builder and much more. There’s no docker image that I know of, so this won’t be as smooth as other requests. But… I request! And thanks!
Hey @box2321!
Thanks for your suggestion!
Unfortunately, there’s only an amd64 Docker image available for Amusewiki. A multi-architecture image (e.g., for ARM devices like the Raspberry Pi) isn’t currently provided.
Here’s the repo: GitHub - rojenzaman/amusewiki-docker: Production-ready docker images for AmuseWiki.
That said, I can still make the app available. It will just only work on amd64 systems.
Added Papra.
Thanks for the speedy answer! Sounds like Amusewiki would work on the Umbrel Home? I use mine daily and this would be a great addition, if not too much trouble! Thanks!
I’ll give it a try, but it might take a bit of time. I’ve got a few other things in the pipeline at the moment.
Thanks for your patience, and I’ll keep you posted! ![]()
Added Websurfx.
Hey @aleonel!
Huge thanks for the awesome support!
I just added Pinchflat. Hope it fits perfectly!
If you have any other ideas or requests, just shout! ![]()
Added Pinchflat.
Added BIP47 Message Verifier.
