Dennys Umbrel App Store ☂️
Added KitchenOwl.
Looks like it used to run on 8787 but was moved to 8789 for Rstudio to take it’s place.
Not loading because of:
GET http://umbrel.local:8787/assets/manifest.json net::ERR_CONNECTION_REFUSED
Looks like the ENV var for the docker container still thinks it’s on 8787 and only the umbrel store yaml was updated.
I tried to submit a github issue or PR but don’t have permissions for either.
I did fork your repo, modify it, and test that it resolves the problem.
Thanks for your aggregations - lemme know if there is a better way to report things like this!
Hey @mark.bluhm!
Hey, thanks a lot for the heads-up! :+1:
I had to use the port for another app at some point and totally forgot to update it in the docker-compose.yml - classic :sweat_smile:
It’s on my list now, and I’ve also enabled Issues on the repo in case you (or anyone else) wants to report something in the future.
Really appreciate you testing and letting me know! :raising_hands:
Added Glance.
Added Tillywork.
Added Wiki-Go.
Added GoMFT.
Added Karakeep.
Added SiYuan.
Added Gotify.
Added IT-Tools.
Added slskd.
Could you add Kavita (The Book reader)
Added Kavita. (Suggestion from @Bubbywoodz)
Hey Denny can you add Honeygain please?
Hey @skidmore298!
Thanks for your suggestion, I’ll take a look at the app. :flexed_biceps:
Added Ente Photos.
Added Ente Auth.
Hey @skidmore298!
Thank you for suggesting Honeygain for the App Store.
However, I see significant privacy risks with this app. Users share their IP address and bandwidth with third parties without knowing exactly how it will be used. Even though Honeygain claims to encrypt the data, there remains a risk that the connection could be exploited for unwanted or even problematic purposes.
Prioritizing privacy and security, I won’t be adding this app.
I hope you understand and aren’t upset about this decision! :blush:
Added Spooty.
