Hi -
Background
I recently logged into my umbrel after 6 days of no use, was assuming it was active.
When I returned to the node, I logged in, balanced weren’t showing and hard drive was filled 950gb of system data
I tried pulling logs via settings, they failed to load, then I trigged a shut down which hanged and I manually unplugged after 15 minutes.
After startup umbrel UI indicated docker images failed to start
I logged in via ssh, and noticed the hard drive now is unexpectly indicating nearly 100% free space
I ran debug script, then saw docker images were failing to start due to missing config
So I ran scripts indicated here Error: Failed to start containers - #7 by 21isenough
After doing that, when accessing via Umbrel UI
I either see “welcome to umbrel” with a disabled “loading” button
or Sometimes the docker services startup error page loads
Running fsck reported no errors
I believe I have lost my channel data
when I look at the file tree, I don’t see files I’d expect to find
- lnd/data/graph/mainnet/ only has channel.db but file size seem small
- db/umbrel-seed is empty
Tomorrow I’ll try with a fresh SD card, but I worry the issue lies with the SSD
The support I need
I’d very much appreciate some support with these two pieces.
is there any additional triage steps I can do?
I’d like to initiate force close on my channels but I’m not confident my channels.backup is up to date, can I request the latest backup ( I do have a backup of the seed ) ?
I appreciate the support, there is a significant amount of funds within these channels. I’d like to close them asap.
Thank you
