hi,
Is there a way to use the same Lightning wallet, both on Umbrel and Bluewallet (or other app), similar to using private keys on a BTC wallet?
I setup my lightning node but can’t manage to “link” the lightning balance of my Umbrel wallet to the one on my phone.
I just managed to connect Bluewallet lightning to the umbrel node, but it is using a separate Lnt wallet (i.e. I would need to transfer the funds from umbrel wallet to bluewallet, which defeat the purpose of using Thunderhub…)
Thanks for your help.
- BTC node is setup
- Lightning node is setup on Umbrel, incl. Thunderhub
- BTC Bluewallet on iphone is setup (same private keys than Umbrel wallet)
- Lightning Bluewallet on iphone is setup, connecting with to the umbrel node
