My channels have been offline for quite some time and I just noticed that synced_to_chain and synced_to_graph are both FALSE in LND. I can’t figure out how to fix it.
Things I’ve done:
- Restart several times
- Uninstall and reinstall all apps
- Upgrade to 0.5.0 via manual reflash of my SD card
- Followed the troubleshooting guide*
*This last step didn’t get me anywhere. I followed the steps under “After a bad shutdown, the node is not syncing” as well as “What is the procedure to rescan wallet UTXOs?” but the terminal throws errors on all the commands given… various files or directories not found. Perhaps this is because 0.5.0 changed the directory structure and the troubleshooting guides need to be updated?
Any help would be much appreciated!
edit: log file attached: umbrel-1654780872443-debug.log (30.1 KB)
