Channel opening issue
Has anyone else had an issue with new channels, where the channels are opened with 0/0 fees (and not the default fee set in lnd.conf) and not announced to the network until node/lnd is restarted? Is this issue with lnd reported on Github?
Yes I can confirm to have the same issue since the last update of Umbrel.
Not sure if that also happens when you open a channel the normal way. I have only opened dual funded balanced channels through BOS (Balance of Satoshi script) and every time the channel shows 0/0 fees and they can not be edited until a restart. I would say this is definitely a bug introduced with the latest update.
