So opened a channel with bfx-lnd1 the other day and while its open. I can’t do anything with it. No amboss channel details comes up, I can’t even close the channel. Any idea what to do on this one?
Is it maybe a private channel you opened ? You won’t see those on Amboss or 1ML.
Standard Thunderhub open, certainly acts like a private channel though. I think I maybe I got caught up in that last LND update? I did fortunately gain the ability to balance the channel now and change rates. So least LNDg can use the channel now.
Sadly the recent update doesn’t seemed to have triggered the channel details to emerge. https://amboss.space/edge/759151x2204x0 just gives me a blank page. According to Amboss nothing is coming from the channel, and 1ml.com has nothing as well. so kinda at a loss a on this one. Worried since it opened bad, what will closing do…
Some LNDg info:
Capacity: 10,000,000 | Is Open: True | Is Active: True | Is Private: False | Channel Updates: 48
Channel Point: 04b1b0802e0861123f35f642442158396ad16539e8fcbefaba831495f97850c7:0 | Opened In: 759,151 | Opener: Local
