Cannot remove watchtower client node
Hi all,
I have one watchtower client node (tower) configured which is no longer existing. And one tower which is working.
With advanced settings in Lightning Node, there is a trashbin icon that I assume is for removing a tower. However clicking that icon, nothing happens.
Using lncli I can see both towers are configured:
umbrel@umbrel:~$ sudo docker exec lightning_lnd_1 lncli wtclient towers
    "towers":  [
            "pubkey":  "020redacted",
            "addresses":  [
                "s5mredacted.onion:9911"
            "active_session_candidate":  false,
            "num_sessions":  0,
            "sessions":  [],
            "session_info":  [
                    "num_sessions":  0,
                    "sessions":  [],
                    "policy_type":  "LEGACY"
                    "num_sessions":  0,
                    "sessions":  [],
                    "policy_type":  "ANCHOR"
                    "num_sessions":  0,
                    "sessions":  [],
                    "policy_type":  "TAPROOT"
            "pubkey":  "037redacted",
            "addresses":  [
                "k3alilredacted.onion:9911"
            "active_session_candidate":  true,
            "num_sessions":  1,
            "sessions":  [],
            "session_info":  [
                    "num_sessions":  1,
                    "sessions":  [],
                    "num_sessions":  26,
                    "sessions":  [],
                    "num_sessions":  1,
                    "sessions":  [],
I managed to deactivate the tower “020…”, however I cannot remove it:
umbrel@umbrel:~$ sudo docker exec lightning_lnd_1 lncli wtclient remove 020redacted
All I get is these curly brackets as an answer. And if I list the towers, it is still there.
Any ideas how to get rid of it?
I tried also to remove it with the onion address appended, then I get:
[lncli] rpc error: code = Unknown desc = cannot remove last tower address
