Brcly's Community App Store - Gaming Edition šŸŽ®
Hey guys,
I’ve implemented a couple of docker images to my Umbrel & in-turn have created a community app store to coincide with them.
Though I’m not new to self-hosting & coding / programming in general, I’m new to messing about with Docker, JS, any web-based coding & in-turn Umbrel in this way. My implementations of the apps work, but there’s of course improvements that can be made.
Find it here:
My biggest hurdle is currently Crafty, as it’s forces SSL requirements to access so simply clicking the ā€œCraftyā€ app on Umbrel’s homepage doesn’t currently work & neither does using Umbrel’s App Proxy system (if anyone knows how to fix this, then please, I’m welcome to advice).
Currently you have to instead manually direct ā€œhttp://umbrel.local:8543ā€ to ā€œhttpS://ā€ it will then function fine. Default credentials to login for the first time are located at
brcly-crafty/data/app/config/default-creds.txt
which can be accessed through Umbrel’s 1.4+ File system, or manually via SSH/Terminal.
I did attempt to set default credentials for Crafty so less is required for installation, which did initially look like it worked and I could login, but would eventually cause some permission errors and other sorts as Crafty wouldn’t run some first-time setup scripts as it detected a ā€œprevious configā€. I might look at this again at some point, potentially could be fixed with a pre-start script or something, but not right now.
Currently the only apps available are:
  • Crafty
  • Playit.gg
Both I’ve tested thoroughly and I use without issue.
Depending on how things go, I could potentially switch Crafty with a different server management system, which could potentially render the SSL issue obsolete, it’s just currently, for Minercraft (which is all I’ve been testing with) IMO Crafty is currently the :goat:
I’ll update the store descriptions & images Soonā„¢
PLEASE NOTE FOR PI UMBREL USERS
The Raspberry Pi CAN run a Minecraft Server, but to save you time setting one up, don’t bother. The lag just isn’t worth it & any more than 1 person can start causing issues & crashes.
Not everyone will find use with these apps, but the Umbrel Home (and other N100ish type Mini PC’s) is a fairly capable little system, able to host a server & run mods for multiple users (probably like 10-20?) and these apps give hosters the option to self-host instead.
Really good project brother, I’ve created a server in a couple of minutes, thank you.
Good job! :flexed_biceps:
Thanks for creating these Community-Apps! I really enjoy my Minecraft Servers on my UmbrelOS.
But is there any chance that you could update the Container frequently?
