After Updating Bitcoin Core Node to version 28, Bitcoin node would not start (no data displayed on bitcoin node umbrel page).
I investigated bitcoin debug.log first with:
tail -n 1000 /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/debug.log
The relevant lines in the log appear to be this:
[net:error] Unable to bind to 0.0.0.0:8333 on this computer. Bitcoin Core is probably already running.
2024-11-10T18:57:39Z [error] Unable to bind to 0.0.0.0:8333 on this computer. Bitcoin Core is probably already running.
2024-11-10T18:57:39Z [error] Failed to listen on any port. Use -listen=0 if you want this.
2024-11-10T18:57:39Z Shutdown: In progress...
Then it appears, bitcoin core will restart and go through the start-up cycle until it shuts down again with the above error.
I also noted in the github bitcoin core v28 release notices the following:
P2P and Network Changes
Previously if Bitcoin Core was listening for P2P connections, either using default settings or via bind=addr:port it would always also bind to 127.0.0.1:8334 to listen for Tor connections. It was not possible to switch this off, even if the node didn’t use Tor. This has been changed and now bind=addr:port results in binding on addr:port only. The default behavior of binding to 0.0.0.0:8333 and 127.0.0.1:8334 has not been changed.
If you are using a bind=… configuration without bind=…=onion and rely on the previous implied behavior to accept incoming Tor connections at 127.0.0.1:8334, you need to now make this explicit by using bind=… bind=127.0.0.1:8334=onion. (#22729)
Bitcoin Core will now fail to start up if any of its P2P binds fail, rather than the previous behaviour where it would only abort startup if all P2P binds had failed. (#22729)
This last sentence indicates different behavior in Version 28 which shuts down if it can’t bind to 0.0.0.0:8333 (i.e. can’t bind to “any of its P2P binds”).
How do I make sure nothing is already bound to port 8333?
How can i fix this with alterations to umbrel-bitcoin.conf ?
My umbrel-bitcoin.conf has these relevant lines already:
# Enable/disable incoming connections from peers.
listen=1
listenonion=0
i2pacceptincoming=0
[main]
bind=0.0.0.0:8333
bind=10.x.x.x:8334=onion
Just before the update on Version 27 of bitcoin core node, the node had no trouble running and binding to 8333.
Is the workaround below acceptable?
When I change in umbrel-bitcoin.conf from “bind=0.0.0.0:8333” to “bind=127.0.0.1:8333” bitcoind node comes back online (i.e. will not shut down due to failed binding error above) and appears to be working normally.
Have I lessened the nodes security by doing this?
Do I need bitcoind to bind to 0.0.0.0:8333 for other umbrel apps that make use of the node? Given the default setting of binding to 0.0.0.0:8333, not sure this is correct approach.
