Bitcoin Node stuck at starting after upgrading to Umbrel v1.3
I’m experiencing an issue with Bitcoin Node v28.0—it won’t start and remains stuck on “starting” after upgrading Umbrel to v1.3 on a Raspberry Pi 4.
Bitcoin node log:
umbrel_bitcoin_2024-12-24_14-54.log (111.4 KB)
From what I can see in your log, the node tries to start but shows the same error several times:
bitcoin_bitcoind_1 | 2024-12-24T13:52:11Z [error] txindex: best block of the index not found. Please rebuild the index.
Here is a guide to do it:
It is a process that will take some time depending on your hardware.
Thank you. It looks like it worked. The node is running and syncing again.
