Hi, My node is stuck synchronizing on block 596,893. I have a Raspberry Pi 4 with just Bitcoin Node and Electro installed. Troubleshooting has included all hardware replaced except for Raspberry Pi, restarting Umbrel in app, attempted reading debug log for a non-technical person. Any guidance is appreicated.
As a first step you can run the timedatectl command to check if your system clock is still synchronized. I’d also recommend installing an NTP service such as chrony to keep things synchronized https://linuxhint.com/install-ntp-using-chrony-linux/ (follow the Debian install guides), some users are reporting this resolves issues after disconnecting/reconnecting a device.
I’d also like to ask some of the other basic questions:
How is your Umbrel connected to the Internet (Ethernet, WiFi)
What type of drive you are using (HDD, SSD)
Anything else you think can be relevant, especially after you made any hardware changes…
As you swapped out the hardware, are you sure the cable is a USB 3.0 A to USB-C? One easy way to tell is if the end of the cable itself also has a blue finish on the jack. Secondly, try using a different USB 3.0 port, rebooting the router and the Umbrel, and waiting for it to begin syncing once more.
Thank you @usernameisJim for the response! I ran the timedatectl command and confirmed clock is still synchronized. As for installing chrony is that OK do install on Umbrel on my raspberry pi 4?
Answers to questions:
Umbrel is connected to internet by Ethernet
Type of drive is SSD
I was getting several other errors such as: system service failed, failed to start containers, etc. on my previous setup. I tried several troubleshooting steps that seemed to help but never resolved so I gave in and switched from HDD to SSD, switched microSD cards, changed power cable, and USB 3.0 cable (confirmed). Only thing that stayed the same was the Raspberry Pi4. Install seemed to go normal and began downloading blocks then froze on 596,893.
I’m a bit reluctant to set a static IP but open to it. I have the device shutdown for now but will switch 3.0 ports and plan to set a static IP this week but let me know if there is something else missing. Thanks for the feedback!
I am stuck and very slow about 0.1% per day. My ISP does not have a public IP address. How can I improve this ? I am using Umbrel on Virtual Box running on i3-9100 24GB RAM desktop PC. Been synching for 3 weeks already, it was fast at the first 50% getting slower, now its crawling. Hard disk is 1TB, live usage says 303GB remaining. Any idea how to improve the speed?
