Bitcoin Node on RPi Slow to Synchronize after ~65%
True, the final part of the sync is slow regardless of the hardware, but switching USB ports helps. Blocks after 2023 are the wall (65% to 100%), and spam is the cause. So, I’m running Knots and signaling Bip-110.
I’m a little confused. So a USB 2.0 is faster than USB 3.0 in this case?
Yes, in this case (Raspberry Pi 5 + external SSD) “stable” 2.0 USB is better than “fast” 3.0 USB. :slight_smile:
For the IBD, in my experience, the 2.0 USB port fixes the hardware problem.
I installed my BTC node, last Sunday everything was worderful. I have a Raspberry pi 5 with 8 GB RAM, a micro sd 64 GB and a external SSD disc 2TB Phillips brand new everything. I am using Umbrel I just download Bitcoin node and lightning . Sudenly after 24 hours aprox and 65% of the blockchain downloaded, troubles arrived. The velocity decrease to one percent per day, I obviously thought that something wrong happened. I did everything I change the micro sd for a new one, I change the ethernet cable. I did all the possible solutions that IA gave me and it did not work. I am facing exactly the same situation, peers went down to 1,2 no more that 4 , the temperature is 50°C My internet speed is okey. I actually changed the SSD to another USB port 3.0 and it did not work neither. I will change it to the USB 2.0 to see what happens. If anyone find the solution for this issue. I will be looking forward to knowing that. Nevertheless I would like to know how long takes to download the remaining 35 % for each of you.
I wrote Blockchain Sync Monitor for exactly this … to help give you some insight on IBD processing.
But from what I have heard, rPi and external SSD do not perform very well and I am sure that is your bottleneck.
