Bitcoin CLI tool in Umbrel 1.04+
Hi -
I’m grateful for the amazing work with Umbrel 1.0+. I have version 1.04.
At the moment I am wondering where the bitcoin-cli location is, how to best run it since the 0.5 update, and to what depths others use this tool. I have not found enough yet by browsing the recent documentation on this forum since the update.
For example, I would be grateful for the return of the “getblockchaininfo” command which I had previously found helpful.
Cheers,
in versions of umbrel where bitcoin-cli have been depreciated, run;
sudo docker ps -a
that will list out all your containers, then find the one for bitcoind, mine was named “bitcoin_bitcoind_1”
Then you can run your bitcoind or bitcoin-cli commends inside that container for your node.
sudo docker exec -it bitcoin_bitcoind_1 bitcoin-cli -getinfo
good luck
