Are people using a cooling mechanism?
Hi could I ask question can I run a pibow shim fan and program it on umbrel OS instead of PI OS?
Just got umbrel and seen the instructions say use pi os.
Any info on how to do this will be appreciated.
Thanks
dear kguhr, how do you set up the fan or other things for deskpi - i mean if you flash umbrel OS, you do not have the setup files from deskpi ?
Cheers if you can help
Dear DHD,
i am also using Deskpi with my umbrel. I guess I installed the script and I can turn on and off the fan. but the automated mode does not work. also when I shut down my node and restart it again - all gone. Is that all how it should be?`Cheers
