Apps are stuck uninstalling
Apps have been unistalling for over 24 hours. reboot did not solve. node is fully synced.
Any suggestions?
Try rebooting, make sure you reboot via Settings page.
This solved the issue thanks!
also i have a VPN that auto connects. i am not able to access the node when connected but it seems if i access the node and my vpn auto connects the node becomes erratic and things do not proccess properly but i am still able to navigate the OS at that point. My advice would be to make sure VPN does not connect while you are using the node. If there is some VPN setting I could use in conjuction with the node i would love to hear about it!
