After 5.0 update, LND.conf has been erased?
After update to Umbrel 5.0, it looks like my LND.conf file is empty? Has the location been moved?
I tired:
sudo nano ~/umbrel/lnd/lnd.conf
and received:
[ Directory '/home/umbrel/umbrel/lnd' does not exist ]
I also tried
sudo nano /umbrel/lnd/lnd.conf
and received:
[ Directory '/home/umbrel/lnd' does not exist ]
The resulting file is empty (or the system created a new one?)
Is there any way to find and/or restore the old LND.conf file?
Thanks.
Me things they have changed the paths. If you want to check the lnd.log you need to look in umbrel/app-data/lightning/data/lnd/logs/bitcoin/mainnet/lnd.log.
And you can search for the conf by using “find ~ -name lnd.conf”. “~” is the location of your users root dir - which is /home/umbrel.
Thank you! That worked perfectly.
Looks like LND is currently located at: /umbrel/app-data/lightning/data/lnd/lnd.conf
sudo nano ~/umbrel/app-data/lightning/data/lnd/lnd.conf
is the correct command to access LND.conf in the current location.
Hi guys,
this kind of worked for me but not really. Running the find command I got a two hits located in:
/home/umbrel/umbrel/.umbrel-v0.4.10/lnd/lnd.conf
/home/umbrel/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/lightning/data/lnd/lnd.conf
I opened the first file and made the changes I wanted (alias, add watchtower and so on) but after restarting (several times) they don’t really take effect. The second lnd.conf file is almost empty
In the location you posted @Filou I don’t find any lnd.conf file
Anybody having the same issues or with an idea how to edit the conf file as before?
I was about to add the watchtower but when i opened the lnd.conf (located here: sudo nano ~/umbrel/app-data/lightning/data/lnd/lnd.conf) i found already there the lines
[wtclient]
wtclient.active=true
so i assume that from 0.5.0 the watchtower run by default.
in many tutorials I see different ways to restart lnd after a lnd.conf change.
Any of them works on umbrel 0.5.0
Any hint?
Try restarting from the web interface (through settings)
you can also try :
sudo systemctl restart lnd
or
cd ~/umbrel ; docker-compose restart lnd; docker-compose ps
