2FA using Authy does not work after working
After all being fine, I tried to log on my iphone and entering the 2FAcode using Authy did not work on the iphone, then on my PC I disable the 2FA on my main system and turn it on again, now after imputing new codes many times I cannot reestablish the 2FA using safari
pls advise
Make sure that your authy time and the umbrel time match.
Hi, not sure what aor how to do that, it was working fine until I turned off and on again
You can remove 2FA with the following steps:
  2. Type in the following command ssh -t umbrel@umbrel.local and press the Enter key (use your Umbrel instance’s password)
  3. Run sudo yq eval 'del(.user.totpUri)' -i ~/umbrel/umbrel.yaml
Thanks. I use this command to disable the 2FA successfully.
