These are my logs from the last startup slightly after it was finishing the verification. Shortly after many of the warnings appeared (didn’t include them at the end because they are too many).
umbrel@umbrel:~$ cat ~/umbrel/app-data/bitcoin/data/bitcoin/debug.log | tail -n 100
2025-08-13T05:26:56Z Config file arg: chain=“main”
2025-08-13T05:26:56Z Config file arg: datacarrier=“1”
2025-08-13T05:26:56Z Config file arg: datacarriersize=“83”
2025-08-13T05:26:56Z Config file arg: dbcache=“1000”
2025-08-13T05:26:56Z Config file arg: dbcache=“450”
2025-08-13T05:26:56Z Config file arg: i2pacceptincoming=“0”
2025-08-13T05:26:56Z Config file arg: i2psam=“10.21.22.11:7656”
2025-08-13T05:26:56Z Config file arg: includeconf=“umbrel-bitcoin.conf”
2025-08-13T05:26:56Z Config file arg: listen=“1”
2025-08-13T05:26:56Z Config file arg: listenonion=“0”
2025-08-13T05:26:56Z Config file arg: maxconnections=“125”
2025-08-13T05:26:56Z Config file arg: maxmempool=“300”
2025-08-13T05:26:56Z Config file arg: maxorphantx=“100”
2025-08-13T05:26:56Z Config file arg: maxreceivebuffer=“5000”
2025-08-13T05:26:56Z Config file arg: maxsendbuffer=“1000”
2025-08-13T05:26:56Z Config file arg: maxuploadtarget=“0”
2025-08-13T05:26:56Z Config file arg: mempoolexpiry=“336”
2025-08-13T05:26:56Z Config file arg: onion=“10.21.22.10:9050”
2025-08-13T05:26:56Z Config file arg: onlynet=“ipv4”
2025-08-13T05:26:56Z Config file arg: onlynet=“ipv6”
2025-08-13T05:26:56Z Config file arg: onlynet=“onion”
2025-08-13T05:26:56Z Config file arg: onlynet=“i2p”
2025-08-13T05:26:56Z Config file arg: peerblockfilters=“1”
2025-08-13T05:26:56Z Config file arg: peerbloomfilters=“0”
2025-08-13T05:26:56Z Config file arg: peertimeout=“60”
2025-08-13T05:26:56Z Config file arg: permitbaremultisig=“1”
2025-08-13T05:26:56Z Config file arg: persistmempool=“1”
2025-08-13T05:26:56Z Config file arg: printtoconsole=“0”
2025-08-13T05:26:56Z Config file arg: prune=“0”
2025-08-13T05:26:56Z Config file arg: rest=“0”
2025-08-13T05:26:56Z Config file arg: rpcallowip=“10.21.0.0/16”
2025-08-13T05:26:56Z Config file arg: rpcallowip=“127.0.0.1”
2025-08-13T05:26:56Z Config file arg: rpcauth=****
2025-08-13T05:26:56Z Config file arg: rpcworkqueue=“64”
2025-08-13T05:26:56Z Config file arg: rpcworkqueue=“128”
2025-08-13T05:26:56Z Config file arg: timeout=“5000”
2025-08-13T05:26:56Z Config file arg: txindex=“1”
2025-08-13T05:26:56Z Config file arg: whitelist=“10.21.0.0/16”
2025-08-13T05:26:56Z Config file arg: whitelist=“127.0.0.1”
2025-08-13T05:26:56Z Config file arg: zmqpubhashblock=“tcp://0.0.0.0:28334”
2025-08-13T05:26:56Z Config file arg: zmqpubhashtx=“tcp://0.0.0.0:28336”
2025-08-13T05:26:56Z Config file arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
2025-08-13T05:26:56Z Config file arg: zmqpubrawtx=“tcp://0.0.0.0:28333”
2025-08-13T05:26:56Z Config file arg: zmqpubsequence=“tcp://0.0.0.0:28335”
2025-08-13T05:26:56Z Config file arg: [main] bind=“0.0.0.0:8333”
2025-08-13T05:26:56Z Config file arg: [main] bind=“10.21.21.8:8334=onion”
2025-08-13T05:26:56Z Config file arg: [main] port=“8333”
2025-08-13T05:26:56Z Config file arg: [main] rpcbind=“10.21.21.8”
2025-08-13T05:26:56Z Config file arg: [main] rpcbind=“127.0.0.1”
2025-08-13T05:26:56Z Config file arg: [main] rpcport=“8332”
2025-08-13T05:26:56Z Command-line arg: datadir=“/data/bitcoin”
2025-08-13T05:26:56Z Command-line arg: deprecatedrpc=“create_bdb”
2025-08-13T05:26:56Z Using at most 125 automatic connections (1048576 file descriptors available)
2025-08-13T05:26:56Z scheduler thread start
2025-08-13T05:26:56Z Binding RPC on address 10.21.21.8 port 8332
2025-08-13T05:26:56Z Binding RPC on address 127.0.0.1 port 8332
2025-08-13T05:26:56Z Generated RPC authentication cookie /data/bitcoin/.cookie
2025-08-13T05:26:56Z Permissions used for cookie: rw-------
2025-08-13T05:26:56Z Using random cookie authentication.
2025-08-13T05:26:56Z Using rpcauth authentication.
2025-08-13T05:26:56Z Starting HTTP server with 16 worker threads
2025-08-13T05:26:56Z Using wallet directory /data/bitcoin
2025-08-13T05:26:56Z init message: Verifying wallet(s)…
2025-08-13T05:26:56Z Using SQLite Version 3.46.1
2025-08-13T05:26:56Z Using wallet /data/bitcoin
2025-08-13T05:26:56Z Using /16 prefix for IP bucketing
2025-08-13T05:26:56Z init message: Loading P2P addresses…
2025-08-13T05:26:56Z Loaded 11220 addresses from peers.dat 41ms
2025-08-13T05:26:56Z init message: Loading banlist…
2025-08-13T05:26:56Z SetNetworkActive: true
2025-08-13T05:26:56Z Cache configuration:
2025-08-13T05:26:56Z * Using 2.0 MiB for block index database
2025-08-13T05:26:56Z * Using 125.0 MiB for transaction index database
2025-08-13T05:26:56Z * Using 109.4 MiB for basic block filter index database
2025-08-13T05:26:56Z * Using 8.0 MiB for chain state database
2025-08-13T05:26:56Z * Using 755.6 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2025-08-13T05:26:56Z Script verification uses 3 additional threads
2025-08-13T05:26:56Z Using obfuscation key for blocksdir *.dat files (/data/bitcoin/blocks): ‘0000000000000000’
2025-08-13T05:26:56Z Opening LevelDB in /data/bitcoin/blocks/index
2025-08-13T05:26:56Z Opened LevelDB successfully
2025-08-13T05:26:56Z Using obfuscation key for /data/bitcoin/blocks/index: 0000000000000000
2025-08-13T05:26:56Z Using 16 MiB out of 16 MiB requested for signature cache, able to store 524288 elements
2025-08-13T05:26:56Z Using 16 MiB out of 16 MiB requested for script execution cache, able to store 524288 elements
2025-08-13T05:26:56Z init message: Loading block index…
2025-08-13T05:26:56Z Assuming ancestors of block 00000000000000000001b658dd1120e82e66d2790811f89ede9742ada3ed6d77 have valid signatures.
2025-08-13T05:26:56Z Setting nMinimumChainWork=0000000000000000000000000000000000000000b1f3b93b65b16d035a82be84
2025-08-13T05:27:01Z LoadBlockIndexDB: last block file = 4952
2025-08-13T05:27:01Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=71, size=128009116, heights=897145…898169, time=2025-05-17…2025-05-24)
2025-08-13T05:27:01Z Checking all blk files are present…
2025-08-13T05:27:04Z Initializing chainstate Chainstate [ibd] @ height -1 (null)
2025-08-13T05:27:04Z Opening LevelDB in /data/bitcoin/chainstate
2025-08-13T05:27:04Z Opened LevelDB successfully
2025-08-13T05:27:04Z Using obfuscation key for /data/bitcoin/chainstate: 951427f74b2a688d
2025-08-13T05:27:04Z Loaded best chain: hashBestChain=0000000000000000000039787262a18f04c2c3be7a71292f8bde3772e0e603b5 height=897604 date=2025-05-20T20:27:35Z progress=0.972544
2025-08-13T05:27:04Z init message: Verifying blocks…
2025-08-13T05:27:04Z Verifying last 6 blocks at level 3
2025-08-13T05:27:04Z Verification progress: 0%
2025-08-13T05:28:47Z Verification progress: 16%
2025-08-13T05:40:22Z Verification progress: 50%
2025-08-13T05:50:33Z Verification progress: 66%
2025-08-13T06:00:35Z Verification progress: 83%
2025-08-13T06:09:40Z Verification progress: 99%
2025-08-13T06:09:40Z Verification: No coin database inconsistencies in last 6 blocks (14736 transactions)
2025-08-13T06:09:40Z Block index and chainstate loaded
2025-08-13T06:09:40Z Opening LevelDB in /data/bitcoin/indexes/txindex
2025-08-13T06:09:43Z Opened LevelDB successfully
2025-08-13T06:09:43Z Using obfuscation key for /data/bitcoin/indexes/txindex: 0000000000000000
2025-08-13T06:09:43Z Opening LevelDB in /data/bitcoin/indexes/blockfilter/basic/db
2025-08-13T06:09:43Z Using obfuscation key for /data/bitcoin/indexes/blockfilter/basic/db: 0000000000000000
2025-08-13T06:09:43Z Using SQLite Version 3.46.1
2025-08-13T06:09:43Z Using wallet /data/bitcoin
2025-08-13T06:09:43Z init message: Loading wallet…
2025-08-13T06:09:43Z [default wallet] Wallet file version = 10500, last client version = 290000
2025-08-13T06:09:43Z [default wallet] Descriptors: 0, Descriptor Keys: 0 plaintext, 0 encrypted, 0 total.
2025-08-13T06:09:43Z [default wallet] Wallet completed loading in 0ms
2025-08-13T06:09:43Z [default wallet] setKeyPool.size() = 0
2025-08-13T06:09:43Z [default wallet] mapWallet.size() = 0
2025-08-13T06:09:43Z [default wallet] m_address_book.size() = 0
2025-08-13T06:09:43Z Setting NODE_NETWORK on non-prune mode
2025-08-13T06:09:43Z block tree size = 909758
2025-08-13T06:09:43Z nBestHeight = 897604
2025-08-13T06:09:43Z initload thread start
2025-08-13T06:09:43Z Bound to 0.0.0.0:8333
2025-08-13T06:09:43Z Bound to 10.21.21.8:8334
2025-08-13T06:09:43Z Loaded 0 addresses from “anchors.dat”
2025-08-13T06:09:43Z 0 block-relay-only anchors will be tried for connections.
2025-08-13T06:09:43Z init message: Starting network threads…
2025-08-13T06:09:43Z net thread start
2025-08-13T06:09:43Z dnsseed thread start
2025-08-13T06:09:43Z Waiting 300 seconds before querying DNS seeds.
2025-08-13T06:09:43Z init message: Done loading
2025-08-13T06:09:43Z addcon thread start
2025-08-13T06:09:43Z msghand thread start
2025-08-13T06:09:43Z opencon thread start
2025-08-13T06:14:43Z Loading addresses from DNS seed dnsseed.emzy.de.
2025-08-13T06:14:44Z Loading addresses from DNS seed seed.bitcoin.wiz.biz.
2025-08-13T06:14:44Z Loading addresses from DNS seed dnsseed.bitcoin.dashjr-list-of-p2p-nodes.us.
2025-08-13T06:14:45Z Waiting 300 seconds before querying DNS seeds.
2025-08-13T06:15:37Z UpdateTip: new best=0000000000000000000162d5c01459c1bef4f1180610d108090482d956370901 height=897605 version=0x20024000 log2_work=95.619314 tx=1193169030 date=‘2025-05-20T20:47:23Z’ progress=0.972537 cache=2.2MiB(15642txo)
