Updating an Umbrel that has not been updated before
I have found a lot in the community with similar issues i am having getting the 1.5.0 update to work. It looks like i am missing info or files?
has anyone run into these errors or warnings before?
Jan 06 14:48:05 umbrel sudo[543602]: umbrel : TTY=tty1 ; PWD=/home/umbrel ; USER=root ; COMMAND=/usr/bin/mender install https://download.umbrel.com/release/1.5.0/umbrelos-amd64.update Jan 06 14:48:05 umbrel sudo[543602]: pam_unix(sudo:session): session opened for user root(uid=0) by umbrel(uid=1000) Jan 06 14:48:05 umbrel mender[543678]: INFO[0000] Loaded configuration file: /var/lib/mender/mender.conf Jan 06 14:48:05 umbrel mender[543678]: INFO[0000] ‘UpdateControlMapExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the default of 2*UpdatePollIntervalSeconds Jan 06 14:48:05 umbrel mender[543678]: INFO[0000] ‘UpdateControlMapBootExpirationTimeSeconds’ is not set in the Mender configuration file. Falling back to the default of 600 seconds Jan 06 14:48:05 umbrel mender[543678]: WARN[0000] No server URL(s) specified in mender configuration. Jan 06 14:48:05 umbrel mender[543678]: WARN[0000] Server entry 1 has no associated server URL. Jan 06 14:48:05 umbrel mender[543678]: INFO[0000] Mender running on partition: /dev/nvme0n1p2 Jan 06 14:48:05 umbrel mender[543678]: INFO[0000] Performing remote update from: [https://download.umbrel.com/release/1.5.0/umbrelos-amd64.update\]. Jan 06 14:48:06 umbrel mender[543678]: INFO[0000] No public key was provided for authenticating the artifact Jan 06 14:48:06 umbrel mender[543678]: WARN[0000] Returning artifact name from /etc/mender/artifact_info file. This is a fallback, in case the information can not be retrieved from the database, and is only expected when an update has never been installed before. Jan 06 14:48:06 umbrel mender[543678]: ERRO[0000] Download failed: Payload: can not install Payload: rootfs.img: Active root partition matches neither RootfsPartA nor RootfsPartB. Jan 06 14:48:06 umbrel mender[543678]: ERRO[0000] Payload: can not install Payload: rootfs.img: Active root partition matches neither RootfsPartA nor RootfsPartB. Jan 06 14:48:06 umbrel sudo[543602]: pam_unix(sudo:session): session closed for user root
