Update to Bitcoin 28.0 "not running"
Hello, after updating to bitcoin v28 the app just says “not running” I cannot uninstall, do anything in the App Store, right click, or get any functionality after a reboot.
Thanks for any help
I tried this set of commands, with no such luck either
Stop an app:
umbreld client apps.stop.mutate --appId <app-id>
eg.
umbreld client apps.stop.mutate --appId bitcoin
And start it with:
umbreld client apps.restart.mutate --appId <app-id>
I quickly created a test system in Proxmox.
umbreld client apps.install.mutate --appId bitcoin ,
umbreld client apps.uninstall.mutate --appId bitcoin and
umbreld client apps.update.mutate --appId bitcoin
are commands that work without problems on my test system.
I would try to restart the update using the update command.
I hope I could help
