Hi there,
I want to open a big channel but I continue to have this error “Unable to open channel, funding amount is too large, the max channel size is: XXXX BTC”. how can I solve it?
Thanks in advance
Hi there,
Thanks in advance
Under advanced settings in the lightning app (3 dots in the top-right), you can change the default channel settings.
It could also be on your channel partners side.
that’s awesome, thanks you fro the guidance!
