Umbrel up but cant see progress. is it doing something?
Hello,
after a reboot (first sync up to 90% approx) my umbrel started and I cant see progress. Problem is I dont know wether its doing something or not.
Attached some files.
Thanks
debugthorin.txt (24.6 KB)
No, it seems only restarting again and again.
Maybe a hardware issue. You have a 2 GB SSD, this can be problematic, it exceedes USB specification by far and is a heavy load to most power supply.
Try restart Umbrel again. If not restart syncing, you can try to do a user data reset.
sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/lnd/!(lnd.conf) && sudo rm -f ~/umbrel/db/user.json && sudo rm -f ~/umbrel/db/umbrel-seed/seed && sudo systemctl start umbrel-startup
That´s all I can help.
thanks a lot… you are the first to point me in the 2GB SSD direction… I thought it was better to have more space… will tell you how it goes…
The 2TB SSD shouldn’t use up too much power as all SSDs that are on SATA have the same power usage. I have a 8TB SSD running off the USB port and I have no issues, so I don’t know what Lobo is talking about. Maybe reboot the node and see if it works again.
I rebooted now Im here … for the last couple hours
