When I start up umbrel on my raspberry pi, I can’t connect to it. I can see the local IP in Angry IP Scanner and when I try to access at http://umbrel, it holds and then says “this site can’t be reached”.
I can ssh into umbrel@umbrel, so I know it’s alive. Then I do ~/umbrel/scripts/debug --upload, as per the troubleshooting wiki. This prints out the startup logs, which show an error.
How can I resolve this? Logs below
Startup service logs
May 13 23:22:50 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 10.
May 13 23:22:50 umbrel systemd[1]: Stopped Umbrel Startup Service.
May 13 23:22:50 umbrel systemd[1]: Starting Umbrel Startup Service...
May 13 23:22:50 umbrel umbrel startup[4914]: ======================================
May 13 23:22:50 umbrel umbrel startup[4914]: ============= STARTING ===============
May 13 23:22:50 umbrel umbrel startup[4914]: ============== UMBREL ================
May 13 23:22:50 umbrel umbrel startup[4914]: Setting environment variables...
May 13 23:22:50 umbrel umbrel startup[4914]: Starting karen...
May 13 23:22:50 umbrel umbrel startup[4914]: Starting backup monitor...
May 13 23:22:50 umbrel umbrel startup[4914]: Starting decoy backup trigger...
May 13 23:22:50 umbrel umbrel startup[4914]: Starting Docker services...
May 13 23:22:53 umbrel umbrel startup[4914]: tor is up-to-date
May 13 23:22:53 umbrel umbrel startup[4914]: dashboard is up-to-date
May 13 23:22:53 umbrel umbrel startup[4914]: electrs is up-to-date
May 13 23:22:53 umbrel umbrel startup[4914]: manager is up-to-date
May 13 23:22:53 umbrel umbrel startup[4914]: Starting lnd ...
May 13 23:22:53 umbrel umbrel startup[4914]: Starting nginx ...
May 13 23:22:55 umbrel umbrel startup[4914]: Host is already in use by another container
May 13 23:22:55 umbrel umbrel startup[4914]: Starting lnd ... error
May 13 23:22:55 umbrel umbrel startup[4914]: ERROR: for lnd Cannot start service lnd: driver failed programming external connectivity on endpoint lnd (d4e65deb15f1ec2ae993b03317fabc364101ce96d42dc6991acc7c34a19373cd): Bind for 0.0.0.0:10009 failed: port is already allocated
May 13 23:22:55 umbrel umbrel startup[4914]: Starting nginx ... error
May 13 23:22:55 umbrel umbrel startup[4914]: ERROR: for nginx Cannot start service nginx: driver failed programming external connectivity on endpoint nginx (5cf4511cb712d6c8b7dae5dd050f14dd49d2d9bff51de04b3c33343eecbcef37): Bind for 0.0.0.0:80 failed: port is already allocated
May 13 23:22:55 umbrel umbrel startup[4914]: Encountered errors while bringing up the project.
May 13 23:22:55 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
May 13 23:22:55 umbrel systemd[1]: umbrel-startup.service: Failed with result 'exit-code'.
May 13 23:22:55 umbrel systemd[1]: Failed to start Umbrel Startup Service.
