Umbrel not support SSD Realtek RTL9210 M.2 NVME Adapter
New item
ORICO NVMe M.2SSD Model: TCM2-C3
SSD WD Blue SN570 NVMe M.2 2280 1TB
OS Linux umbrel 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarch64 GNU/Linux
umbrel@umbrel:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Then use other os
Example Raspberry os or Debian and Ubuntu it work
root@rpi4-20220121:/# lsusb
Bus 001 Device 005: ID 0483:5750 STMicroelectronics LED badge – mini LED display – 11x44
Bus 001 Device 004: ID 0bda:9210 Realtek Semiconductor Corp. RTL9210 M.2 NVME Adapter
Bus 001 Device 003: ID 1ea7:0066 SHARKOON Technologies GmbH [Mediatrack Edge Mini Keyboard]
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Thank you
Hm, I’m not sure if I’ve seen someone mount an external m2 enclosure for umbrel, can you generate the full logs, paste it into something like 0bin.net and put the link here? Curious to see if Umbrel is able to detect and format it correctly (How to Generate Debugging Logs
