Umbrel not finding network-card / drivers?
This is what i’m getting when trying to install the driver:
Setting up r8125-dkms (9.011.00-3) …
Removing old r8125/9.011.00 DKMS files…
Deleting module r8125/9.011.00 completely from the DKMS tree.
Loading new r8125/9.011.00 DKMS files…
Building for 6.12.48+deb13-amd64
Building initial module r8125/9.011.00 for 6.12.48+deb13-amd64
Sign command: /lib/modules/6.12.48+deb13-amd64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module(s)…(bad exit status: 2)
Failed command:
make -j8 KERNELRELEASE=6.12.48+deb13-amd64 -C /lib/modules/6.12.48+deb13-amd64/build M=/var/lib/dkms/r8125/9.011.00/build
Error! Bad return status for module build on kernel: 6.12.48+deb13-amd64 (x86_64)
Consult /var/lib/dkms/r8125/9.011.00/build/make.log for more information.
dpkg: error processing package r8125-dkms (–configure):
installed r8125-dkms package post-installation script subprocess returned error exit status 10
Processing triggers for initramfs-tools (0.148.3) …
update-initramfs: Generating /boot/initrd.img-6.12.48+deb13-amd64
W: Couldn’t identify type of root file system ‘/dev/root’ for fsck hook
Errors were encountered while processing:
r8125-dkms
Error: Sub-process /usr/bin/dpkg returned an error code (1)
its because you are on a different kernel. use
