Hi folks,
I’m in the following directory: ~/umbrel/app-data/lightning
Trying to export logs using the following command: docker-compose logs -f lnd
I get this error:
services.lnd.ports value [’:’, ‘:’, ‘:’] has non-unique elements
I can’t make sense of this message but y’all are smarter than I am so I hope one of you is able to
