I recently set up my Umbrel node. It has been running for a few days without any issues.
I decided to move my Time Machine backups from my Asustor NAS to Umbrel. There used to be a dedicated app for this, but now it seems the recommended method is simply connecting via the Time Machine settings in macOS.
macOS connects to my Umbrel without any problem, but when I try to create the first backup, I immediately get a red exclamation mark in the Time Machine settings saying:
“The backup disk image could not be created.”
I have no idea why this is happening. I’m following every step exactly as described.
I am also seeing this issue. I have tried a bunch of things but so far I have no resolution. I am absolutely able to access the server from a terminal on my mac and creat files in the mounted SMB share, but time machine complains about it.
Seems to be a problem with the rights of the folders structure timemachine likes to create or rename (and is not allowed to). I have that problem with Tahoe 26.6 on my Macbook.
With an older version of Umbrel (0.5.4) which is still in use on one of my older raspis it still works great with the app “Back This Mac Up”.
Therefore I think it´s a problem with Umbrel 1.5 Files. I also could not figure out how to change rights in general settings or single folders.
I’ve moved on. Installed OpenMediaVault, Tailscale (to ensure my back up works outside local network) and MiniO Community Edition (backing up via Arq 7) on my Pi 5.
Crazy that this hasn’t been patched since November. Guys, you’re selling “all in one” home servers for $600+ and nobody thinks Time Machine being broken for months is a big deal?
It’s not a compatibility issue between SMB and APFS. I run a Time Machine backup with three separate Macs to an SMB share on an Unraid server with zero issues. There is an issue with the folder structure/permissions on Umbrel that is causing this and no one has taken any time to even look at it to attempt to fix it.
The 1.6.1 update seems to have fixed this issue. I am unable to update past 1.5 on my Umbrel Home, but on a new Umbrel Pro with 1.6.1 TM Backups seem to be working as expected.
Time Machine backup problem: fix for authentication error 80
I’m on umbrelOS 2.0 with macOS Golden Gate 27.0.1, backing up to an Umbrel SMB share over Tailscale. My symptom was slightly different from the “disk image could not be created” error in this thread, so it may not match yours, but it might help anyone whose backup fails at the mounting step. I used Claude which was very useful to help me troubleshoot. Please paste this post into Claude if you are not confident with following the terminal commands and it will tell you what to do. However, I would recommend you don’t paste any passwords or your Tailscale IP into the chat with Claude. Also note that Terminal shows nothing while you type a password.
The problem
The share mounted fine in Finder, but Time Machine wouldn’t start. The backupd log showed Authentication error (80).
The cause
Time Machine doesn’t use Finder’s mount. backupd runs as root and reads credentials from the System keychain, not your login keychain. Mine held a stale entry for the share, left over from an earlier folder I’d replaced.
The fix
All the commands below are run in Terminal on the Mac (Applications → Utilities → Terminal). Wherever you see <YOUR-UMBREL-TAILSCALE-IP>, replace it with your own Umbrel’s Tailscale IP address. You can find it in the Tailscale app or admin console.
In Umbrel Files, create a folder with a plain name (I used TimeMachine) and turn on Share over your network. It appears as the share TimeMachine (Umbrel).
In Terminal, run sudo -v and enter your Mac login password. This stops you confusing the sudo “Password:” prompt with the later “Destination password:” prompt.
Set the destination in Terminal, using your Umbrel’s Tailscale IP: sudo tmutil setdestination -p "smb://umbrel@<YOUR-UMBREL-TAILSCALE-IP>/TimeMachine%20%28Umbrel%29"
At “Destination password:”, paste the SMB password using the copy button in Umbrel’s share panel.
If it still fails, delete the old stored entry in Terminal (again using your Umbrel’s Tailscale IP) and redo step 3: sudo security delete-internet-password -s <YOUR-UMBREL-TAILSCALE-IP> -a umbrel /Library/Keychains/System.keychain
To see why a backup failed, run this in Terminal: log show --last 3m --predicate 'subsystem == "com.apple.TimeMachine"' --info | grep -iE "Backup failed|Mounting|Code=|error:" | grep -v "connection invalid" | tail -20
After that, running tmutil status in Terminal showed the phase move from MountingDiskImage to Copying, and the backup completed.
Other tips
“Preparing to back up” can take a long time on the first backup. That’s normal.
tmutil setdestination leaves backups on manual, so run sudo tmutil enable in Terminal afterwards.
Encryption and the disk usage limit can only be set from System Settings → General → Time Machine → Add Backup Disk. An existing unencrypted backup can’t be converted, so switching means deleting it and starting a fresh full backup.
