Syncthing on umbrel, unable to create sync directory
Hey all,
I’m running into a frustrating issue trying to set up Syncthing on my Umbrel. I’m trying to sync a folder from my Mac to my Umbrel, but the remote folder on the Umbrel side fails to initialize with the following error:
2025-09-08 19:18:32: Failed to create folder root directory (folder.label=Downloads folder.id=uksjq-ec4in folder.type=sendreceive error=“mkdir /Apps: permission denied” log.pkg=model)
2025-09-08 19:18:32: Failed initial scan (error=“folder path missing” folder.label=Downloads folder.id=uksjq-ec4in folder.type=sendreceive log.pkg=model)
Here’s what I’ve tried:
My setup
  • Syncthing version: 2.3
  • Umbrel user: umbrel
  • Syncthing process user: Confirmed with ps aux | grep syncthing, it’s running as umbrel
  • Target folder on Umbrel: /home/umbrel/umbrel/home/Downloads
Permissions are OK
drwxr-xr-x 2 umbrel umbrel 4096
any help is appreciated
Hi @fbrichs, I don’t use Syncthing on my Umbrel, but I think Syncthing is unable to find your target directory /home/umbrel/umbrel/home/Downloads because it is running inside a Docker container. Therefore, Syncthing will only have access to the volume defined by the associated docker-compose.yml file.
This file defines the single volume ${APP_DATA_DIR}/data:/var/syncthing. Therefore, if you define your paths in Syncthing to have root /var/syncthing then the files should get written on your host at ${APP_DATA_DIR}/data (I think this would be/home/umbrel/umbrel/app-data/syncthing/data)
Thanks I was able to fix it using the full suggested path /var/syncthing/MYDIR
Hi all,
I try to set up Paperless-ngx together with Syncthing. I´m lost with the volumes config. I unterstand the docker isolation but I hope you can help me.I want to sync the consume folder with a external server using Syncthing.
How I have to config the volume settings in the docker-compose.yml file and what to type in the sync folder at Syncthing?
volumes:
  • ${APP_DATA_DIR}/data:/var/syncthing
  • /home/umbrel/umbrel/home/paperless/consume:/consume
THX
