Hello
I have a strange behavior with my node. I have about 35 channels and route for months almost daily.
From 03.06 suddenly nothing was routed for 10 days.
I thought maybe it was because I had unknowingly misconfigured LNDg. After I had uninstalled it but still nothing was routed. Then I installed LNDg on 13.06 again. And suddenly 10 payments were routed on 13.06 again. Only since then it does not route again.
Maybe that is with LNDg also only a pure coincidence. I know myself for it simply too little.
Sending and receiving payments are no problem with the node. I have tested it successfully.
Are there perhaps certain services that I should check? Restarting the node does not bring any improvement.
Thanks for your help.
