DeviceUmbrel Home (2024)
Model numberU130121
Serial numberU240500333
I usually use private/public rsa keys to ssh between my computers. Home server always asks for password, which is OK but does not allow me to run automated crond rsync scripts.
My questions are: if I change the sshd_config file (displayed below) to login ONLY with rsa key,
a) will the graphical terminal work?
b) I think I need a .ssh folder with keys etc in the /home/umbrel Correct?
c) setting up the rsa only log in one could lock himself up for ever. Only rebooting with a console would give you a way to unlock. I do not see a way to do it with Home Server. I hope there is one.
Clip of sshd_config file:
This is the sshd server system-wide configuration file. See
sshd_config(5) for more information.
This sshd was compiled with PATH=/usr/local/bin:/usr/bin:/bin:/usr/games
The strategy used for options in the default sshd_config shipped with
OpenSSH is to specify options with their default value where
possible, but leave them commented. Uncommented options override the
default value.
Include /etc/ssh/sshd_config.d/*.conf
#Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key
Hostkey /etc/ssh/KenPaoloServers_id_rsa
#HostKey /etc/ssh/ssh_host_ecdsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
HostKeyAlgorithms +ssh-rsa,ssh-dss
Ciphers and keying
#RekeyLimit default none
Logging
#SyslogFacility AUTH
#LogLevel INFO
Authentication:
#LoginGraceTime 2m
#PermitRootLogin
#PermitRootLogin prohibit-password
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
#PubkeyAuthentication yes
Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody
For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
Change to yes if you don’t trust ~/.ssh/known_hosts for
#IgnoreUserKnownHosts no
Don’t read the user’s ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
