Hello,
After more than 48 h after full sync an applying the instructions from “Connect wallet”, I can’t make Sparrow work. Wasabi is working but Saprrow is not working…
The only suspect info in logs is about electrs logs. Should I re-index? If yes, how to do this if I am not home to ssh it?
Thanks,
electrs logs
Attaching to electrs
electrs | [2021-12-23T18:41:51.250Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 56, 194, 196, 97, 13, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 144, 76, 76, 183, 32, 141] }
electrs | [2021-12-23T18:42:47.464Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 162, 194, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 18, 130, 60, 52, 32, 141] }
electrs | [2021-12-23T18:47:01.456Z INFO electrs::chain] chain updated: tip=0000000000000000001567d25210f8c3abaefe8b668cb408131ac69ac3fe9a67, height=596830
electrs | [2021-12-23T18:47:18.789Z INFO electrs::index] indexing 2000 blocks: [596831…598830]
electrs | [2021-12-23T18:47:18.949Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 199, 193, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 135, 181, 165, 87, 32, 141, 216, 194, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 70, 81, 37, 76, 32, 141] }
electrs | [2021-12-23T18:47:42.919Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 21, 196, 196, 97, 73, 4, 0, 0, 0, 0, 0, 0, 38, 4, 168, 128, 4, 0, 0, 208, 0, 0, 0, 0, 28, 70, 240, 1, 32, 141, 44, 196, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 42, 1, 4, 248, 1, 145, 98, 226, 0, 0, 0, 0, 0, 0, 0, 2, 32, 141] }
electrs | [2021-12-23T18:50:08.474Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 148, 196, 196, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 13, 126, 218, 145, 32, 141] }
electrs | [2021-12-23T18:57:11.437Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 144, 196, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 91, 13, 191, 12, 32, 141] }
electrs | [2021-12-23T18:59:11.456Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 72, 198, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 42, 1, 4, 249, 0, 42, 9, 231, 0, 0, 0, 0, 0, 0, 0, 4, 32, 141, 208, 196, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 42, 4, 69, 64, 114, 16, 94, 0, 33, 135, 157, 13, 24, 90, 174, 222, 32, 141] }
electrs | [2021-12-23T19:05:09.682Z INFO electrs::chain] chain updated: tip=00000000000000000011035c2ef7170231f26cff03287a9ea974bf4ea7313bc2, height=598830
electrs | [2021-12-23T19:05:31.184Z INFO electrs::index] indexing 2000 blocks: [598831…600830]
electrs | [2021-12-23T19:06:43.816Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 127, 200, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 24, 194, 40, 125, 32, 141] }
electrs | [2021-12-23T19:07:56.065Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 119, 200, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 64, 182, 69, 130, 32, 141] }
electrs | [2021-12-23T19:11:13.888Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 131, 199, 196, 97, 12, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 95, 191, 131, 126, 32, 141] }
electrs | [2021-12-23T19:11:50.946Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 196, 200, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 98, 224, 28, 183, 32, 141] }
electrs | [2021-12-23T19:19:37.560Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 209, 202, 196, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 77, 164, 213, 131, 32, 141] }
electrs | [2021-12-23T19:20:36.353Z INFO electrs::chain] chain updated: tip=000000000000000000087447f8d312363d59f18f32642720bcb1cf5ea970c8b3, height=600830
electrs | [2021-12-23T19:21:03.510Z INFO electrs::index] indexing 2000 blocks: [600831…602830]
electrs | [2021-12-23T19:21:06.338Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [3, 107, 203, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 99, 88, 47, 34, 32, 141, 207, 203, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 42, 2, 194, 7, 32, 20, 135, 87, 0, 0, 0, 0, 0, 0, 0, 1, 32, 141, 20, 203, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 70, 123, 142, 252, 32, 141] }
electrs | [2021-12-23T19:24:57.428Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 236, 202, 196, 97, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 170, 75, 170, 229, 153, 220] }
electrs | [2021-12-23T19:27:08.231Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 167, 203, 196, 97, 13, 4, 0, 0, 0, 0, 0, 0, 42, 1, 4, 248, 1, 144, 113, 175, 0, 0, 0, 0, 0, 0, 0, 2, 32, 141] }
electrs | [2021-12-23T19:27:30.596Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 217, 203, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 185, 135, 150, 201, 32, 141] }
electrs | [2021-12-23T19:29:29.611Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 254, 204, 196, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 174, 114, 250, 86, 32, 141, 11, 206, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 162, 239, 57, 201, 32, 141] }
electrs | [2021-12-23T19:33:03.404Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 9, 205, 196, 97, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 159, 89, 152, 194, 32, 141] }
electrs | [2021-12-23T19:35:12.285Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [3, 74, 205, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 212, 102, 34, 244, 32, 141, 22, 205, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 75, 9, 151, 174, 32, 141, 70, 205, 196, 97, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 121, 204, 121, 182, 32, 141] }
electrs | [2021-12-23T19:37:00.359Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 223, 206, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 135, 181, 62, 125, 32, 141] }
electrs | [2021-12-23T19:39:09.283Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 173, 207, 196, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 104, 199, 56, 247, 32, 141] }
electrs | [2021-12-23T19:39:34.735Z INFO electrs::chain] chain updated: tip=00000000000000000006b7e7c0d8ae650f6ab37479d45ef04ccfc3e532a9bbd4, height=602830
electrs | [2021-12-23T19:39:59.155Z INFO electrs::index] indexing 2000 blocks: [602831…604830]
electrs | [2021-12-23T19:39:59.239Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 88, 208, 196, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 103, 47, 192, 15, 32, 141] }
