Since the latest upgrade I no longer have to log in at all
Since the latest upgrade 0.5.4 I no longer have to log in. Previously I would be automatically logged out after approx 20mins of inactivity but not any more. It will stay logged in even if not used all day.
Even after a reboot I’m logged straight in without being asked for a password.
Bit of a worry security wise
Thanks for bringing this up I’m confirming with the team the logic for this and will get back to you ASAP and confirm if/why there was a change
Yes, I have similar issue. No auto logout after a period of inactivity.
okay, then I will wait for an official answer before I install ist update.
Cheers Jim
Hey folks, happy to confirm that in this release, we increased the login session expiry to 1 week to remove the inconvenience of logging in every hour. And of course, if you happen to log into your Umbrel on a shared computer/device, it’s recommended that you logout to make sure there’s no unauthorized access from someone else.
This is absolutely bullshit! Please give us a option to set the expiration time in the setting!
Thanks for the response
The constant logging in was a bit of a pain but now i know the change is a feature & not a bug I can once again relax
Agree! I welcome a logout time option as well.
