Several Weeks Waiting on Wallet Synchronizing -- Bitcoin Core at 100%
It has been two full weeks since originally syncing Bitcoin Core at 100%.
  • I am running Umbrel on a Raspberry Pi 4.
  • I am using a 1TB SSD.
  • I am directly connect to Ethernet.
Here are the logs: https://pastebin.com/2nHVjsQQ
I have re-flashed my microSD twice with no changes.
I have also SSH’d into my Umbrel and attempted this command:
A few key log errors:
  • UnhandledPromiseRejectionWarning: LndError: Unable to list channels
  • Unable to list pending channels, wallet not created, create one to enable full RPC access
  • LndError: Unable to list pending channels
I’m beginning to think there is no fix for this bug.
If you do not have any funds in that node, I suggest to start from scratch, wipe everything and start a new instance. Possible that in the past, some files get corrupted and your user data cannot create a lnd wallet.
Instead of trying to fix, is much easier and clean to start a new node instance.
If you had funds in that node and you have a backup of your LN channels, then just restore the funds into Blixt wallet and start from scratch a new umbrel instance.
Here you have a guide how to recover your funds
Thanks this was great advice - I have been struggling with this issue for months but starting from scratch was pretty quick and painless.
@wip3d I’m facing a problem somehow similar to yours. Have you solved it?
