Every torrent app on umbrel wont let me seed. Is there a way to do it?
Hello have you made sure to open the port on your router to make sure you are connectable? I currently run transmission as my seedbox for both public and private trackers no problem.
There is an easy way to check to see if your port is open on transmission by going to the drop down. Right under Acions goto edit preferences > Network and then check under listening port to ensure that you have the port open and transmission is able to seed traffic.
Ill have to ask my roomate about that. Its his router.
Yeah we tried to open a port but its still not working. My roomate thinks its our isp
