Does running umbrel and the node via tor block my ip address from other nodes? Thanks for any help
How does running on tor actually improve privacy?
no you can still connect to clearnet und tor nodes.
the tor network is hiding your ip kind a like a vpn because you’re connected trough a different server which hides your true identity and improves privacy a lot.
cheers
Thanks for the reply. So how is running via tor better than using tail scale? Or should you really do both? But give tailscale alias email?
