Running Umbrel for small Canadian offices: keeping files, backups and app data in Canada
I’m looking at Umbrel as a small home-office server for a few Canadian clients, and some of them have to keep personal data in Canada because of PIPEDA, plus stricter public-sector rules in BC and Quebec. Here’s the checklist I’m working from. I’d like to hear what others would add.
  1. Keep the Umbrel box on-site in Canada, and know which apps store data locally and which ones sync to an outside cloud.
  2. For file, photo and document apps, check where any sync or sharing relay is hosted before turning it on.
  3. Send backups only to storage in Canada, such as a second local drive or a Canadian object storage provider, and encrypt them.
  4. Review each app’s telemetry and update settings, and turn off anything clients haven’t approved.
  5. Use strong passwords and two-factor login, and limit remote access to a VPN rather than open ports.
  6. Test restoring an app and its data on a regular schedule, not just the backup job itself.
  7. Write down which apps hold personal data and where every copy lives, so clients can answer audit questions quickly.
For those using Umbrel for work data: how do you handle off-site backups so nothing leaves the country?
One thing to check before rolling this out for clients: the downloads page (Download umbrelOS) says umbrelOS is free for personal use and is licensed under the PolyForm Noncommercial License. Setting it up for business clients sounds like commercial use to me, so I’d get in touch with Umbrel first and get their OK on licensing. The page lists partner@umbrel.com for licensing and partnerships, so that’s probably the place to start.
On the backups question, umbrelOS has built-in backups under Settings, and as far as I know they’re encrypted and can go to a USB drive, a NAS on your network or remotely over Tailscale, or another Umbrel. So the easiest way to keep every copy in Canada is a second Umbrel or NAS at another location you control, reached over Tailscale, plus a USB drive you rotate off-site. If you’d rather use Canadian object storage, I don’t think the built-in backups can target that, so you’d need a separate backup tool pointed at a bucket in a Canadian region.
The rest of your list looks good to me. I’d just add keeping the box on a UPS so a power cut doesn’t take it down mid-write.
