Need a Dedicated app for Umbrel
Need a Dedicated app for accessing and creating backups for Umbrel for our Phone,PC
and also need a backups option to back up everything from Phone,PC
Check https://github.com/getumbrel/umbrel/issues/2090
It costs a lot of effort and money, you can access from anywhere with an internet browser, what’s wrong with that? :thinking:
Okay no app needed but need backups of our entire phone in the Web UI no dedicated apps
app needed because it’s too laggy
but if there is an option to back up our whole pc and mobile using web ui then it’s okay
But that depends on what phone you have and how it creates a backup, you should be able to use Nextcloud, Seafile or whatever you feel comfortable with, and create your backup there with whatever you want, you could try Syncthing, Borg Backup, Restic, etc.
In the case of the phone, on Android you should be able to create a full backup (search for backup in settings) through Webdav (either Seafile or Nextcloud support it), on iOS I’ve no idea but there should be something too.
