RTL (Ride the lightning)problem
first thanks for umbrel’s team, a beautifull and easy using os.
my problem is:
bitcoin node works fine, core lightning node works also good.
but the RTL can not open? any help will be appreciated.
here is the log:
tor_server-1 | Jan 04 08:57:18.000 [warn] Problem bootstrapping. Stuck at 14% (handshake): Handshaking with a relay. (Connection timed out; TIMEOUT; count 43; recommendation warn; host AA4644F0EC589EEA2F501BB867E32E599F8169DA at 107.189.28.84:9000)
tor_server-1 | Jan 04 08:57:18.000 [warn] 42 connections have failed:
tor_server-1 | Jan 04 08:57:18.000 [warn] 29 connections died in state handshaking (TLS) with SSL state SSLv3/TLS write client hello in HANDSHAKE
tor_server-1 | Jan 04 08:57:18.000 [warn] 11 connections died in state connect()ing with SSL state (No SSL object)
tor_server-1 | Jan 04 08:57:18.000 [warn] 2 connections died in state handshaking (Tor, v3 handshake) with SSL state SSL negotiation finished successfully in CLOSED
I think the problem is the tor…
must RTL use the tor???
