Repair suggestion
I just restarted it this morning, so I will run through this list and get back to you with the results…thank you so much for taking the time!
I don’t know if it created the lightning backup, but when I tried to move it, it gave an error; I couldn’t see the file in File Browser, so I am stuck there.
I am not sure if I did this step right, but I am confused by what your mean by “tile”…was this a typo?
  1. Add reindex=1 at the end of the tile
I just corrected the typo yes. That was supposed to be “file” not “tile”
What error are you seeing and when?
Ok, I edited the file to redindex and restarted. While that’s going, I have a couple questions…what exactly is a reindex? Is it like a resync? Secondly, what do you mean by “monitor the log file”?
Btw, have you ever considered doing Youtube videos like BTC Sessions? You seem to be really knowledgeable about this
Also, while it is trying to reindex, I don’t have any peers or connections (which also was the case before). Nothing has changed since I synced it to where it is today, which is 59.68%. I am on a wired connection connected to fiber internet, so speed shouldn’t be a problem; it is also connected because I am able to get updates and download anything I need to (except the blockchain)
I wonder if maybe you’re having a DNS issue. I don’t remember seeing any errors for DNS resolution in your log files. I would think not finding peers would indicate a network related issue, and DNS is used to discover bootstrap severs.
how would I go about correcting that?
