Relocating a node in different timezone
Hey there, planning a relocation soon and wondering if I need to consider anything before doing so? Thanks in advance
??? Well, I can´t remember configuring time in my node…
Well… there’s an option on TBM, but probably is just for the display time, not sure… can it cause possible issues with btcCore sync?
The node will be offline for nearly two days so also planning to contact (via ThunderHub > chat) the Peers who have channels open with, to let them know (and ask to NO force close channles). But as not sure how many of them use TH, I’ll probably send out a message on Amboss too…
There’s anything else I should consider doing before shutting down?
Bitcoin have ONLY one timezone: UTC. It doesn’t matter where you are with your node, it always beat on that timezone.
